JD 1010 Crawler Question
Pete Holmander
04-03-2005 05:35:31
Can the 1010 transmission be repaired without having to split the tractor re: through the top access covers?
dsldr
04-03-2005 17:14:50
 Re: JD 1010 Crawler Question in reply to Pete Holmander, 04-03-2005 05:35:31
Depends on what needs to be done. If you want to fix the shift mechanism, you are all set. If you need to get to gears, open 'er up and split 'er in two.
Lavoy
04-03-2005 22:31:01
 Re: JD 1010 Crawler Question in reply to dsldr, 04-03-2005 17:14:50
You almost could call it splitting it in fours, because you will most likely end up pulling both finals as well.
Lavoy
