TD14 Steering Clutch problem
JPatton
04-09-2005 19:54:40
Gentlemen - This is not my usual board but I have always found expert advice on all the boards here at YTmag. Here is my problem: I need to move some dirt for a building site. My neighbor has a TD14 that will run and go but the problem is the right clutch will not disengage. Worked OK about 4 years ago but not now. The left clutch operates normally but when you pull back on the right handle, it does not disengage. This might be a clue....The handle does not stop in the detent when pulled rearward like the right handle. Instead, I will come all the way back this it almost hits the seat. Any help will be appreciated. Thanks J
PD Mechanical
04-10-2005 06:05:05
 Re: TD14 Steering Clutch problem in reply to JPatton, 04-09-2005 19:54:40
third party image
If the clutch is not stuck too bad you can try bumping a tree or some other immovable object with the lever pulled back. Sometimes this will break them loose. Also to the best of my knowledge there is no detent in the steering levers. I have worked on many of the TD series crawlers and never come across one with detents. The detent you are refering too may be an overcenter problem of some sort or just rust. If you end up having to pull the steering clutches out we have new discs available as well as some used parts. Be sure to check us out on the web at pdmechanical.com
JPatton
04-10-2005 06:13:08
 Re: TD14 Steering Clutch problem in reply to PD Mechanical, 04-10-2005 06:05:05
PD - Thanks for the suggestion. Yeah, you are right. The detent must be the disengaged-overcenter feel. I have operated this machine a long time ago. My memory isn't what it used to be.
Thanks
J
hector gemme
04-10-2005 03:19:19
HI I thank you have a stuck stering cluch or no more good I have some use td14 parts.HECTOR
captain_crunch
04-09-2005 22:20:15
Try the IH Construction Equip section of Red Power Mag Sounds like clutch pack has stuck
JPatton
04-10-2005 05:29:00
 Re: TD14 Steering Clutch problem in reply to captain_crunch, 04-09-2005 22:20:15
Captian_Crunch - Thanks for the advice. I spent several hours last night going through the archives here before I posted my question. I also looked on the RedPower board. I think I can safely say the clutch is stuck. My question is "how to unstick it?" This is my retired neighbor"s military machine. Although he has said I can use it, he isn"t very interested in spending money to fix it. It is drivable as is but needs to me moved 6 miles to the building sight. I sure would like to be able to steer before hiring a truck to move it.
Thanks J
captain_crunch
04-10-2005 22:21:20
 Re: TD14 Steering Clutch problem in reply to JPatton, 04-10-2005 05:29:00
You can get it loaded by backing up and useing opposite steering clutch. What I have done is adjust steering clutch so the 4" free play is gone and work it and keep clutch pulled back if not stuck too badly the heat will sometimes cause it to free up But make sure you grease the steering clutch throw out bearing often while doing this. Grease fittings for this are under seat bolted to the deck and stick up slightly
Brian
