john van 450 counterweight
stressfree
04-11-2005 03:03:02
john put the 450 backhoe brackets on and tried the loader without it.loaders useless.making brackets to mount counterweight on backhoe brackets.farmer told me to make brackets like on the front of a farm tractor and add weights.his tractor had over a 1000 pound.100 lbs a weight.that might be an idea.
John Van Valkenburgh
04-12-2005 15:58:47
 Re: john van 450 counterweight in reply to stressfree, 04-11-2005 03:03:02
I found a couple of 450 rear counterweights but both are simply too far away to ship to NC. The counterweight I found in CA is going for almost a give-away price too.
There is a place in Goldston NC where they dismantle old machines. I sent them an email several months ago but never got a response. I'll have to give them a call and see what they've got. Its a couple of hours drive from me so I could go get it myself.
I'm mostly working on the 188 engine rebuild at the moment. Got the in-frame kit in today. Looks nice. I've got the head apart and ready to get it surfaced. I'm going to look around for a good set of used injectors. The pencil injectors are not really rebuildable, but I'll settle for a set thats been cleaned up and calibrated.
That cast iron oil pan sure was a pain to get out. Had to loosen the 3 engine mounts, raise the engine a few inches and tilt it slightly to get clearance to pull the pan. The bottom of the pan has what looks like a plate where a torque rod might be mounted. Gets in the way of the rear crossmember. Makes me wonder if the engine came out of something other than a crawler since its not connected to anything as far as I was able to tell.
John
stressfree
04-12-2005 17:44:17
 Re: john van 450 counterweight in reply to John Van Valkenburgh, 04-12-2005 15:58:47
hope you ran the loader on railroad ties or your squeezing under it.i run mine up on heavyduty truck ramps.spent all weekend makeing brackets to mount counterweight on backhoe brackets.hey it works.lifted weight with bucket to set in bracket nose went right down.that weight is heavy.if i come across a weight ill give you a holler.
04-12-2005 19:27:38
 Re: john van 450 counterweight in reply to stressfree, 04-12-2005 17:44:17
You bet that weight is heavy. Something like 1500 lbs. I had the good sense to run the loader up on a pair of 4x6 boards. I've been under it when its on the ground and its a tight fit.
John
1968 Case 450
stressfree
04-13-2005 02:46:29
 Re: john van 450 counterweight in reply to John Van Valkenburgh, 04-12-2005 19:27:38
john when your under there check the front motor mount bolt.see what you have to do to change it.couldnt change mine when i did the pump,i would have had to taken off the belly pan.mine was worn also the radiator mounts were loose.
