Oil spills and the law
jdemaris
04-12-2005 10:49:04
Well, as I said, they're easy to screw up. I worked as Deere mechanic for a long tme, and seen a lot of leaks after filter changes. For installing, the way that works best for me - is - put the o-ring in first, on the tractor - not on the canister. Heavy grease will hold it up in place. Then do as aforementioned. If you try installing with the o-ring on the canister, it will be more apt to cut the ring. As far as a groove being better than the shoulder that's used - yes - or better yet, a throw-away cartridge. The way laws are now as they relate to oil spilled on the ground, some of these older tractors are almost impossible to service out in public view. One case in point - I had to go out and service a brand new backhoe and a crawler - first 100 hour service. It was for a town government. I got there, and there was a newspaper reporter, the town mayor, and a few other officials doing a photo-op about the new equipment that had been purchased. I had to make up a story and leave. I didn't dare to the work because it was virtually impossible to do the job without spilling some oil.
Skip in CT
04-12-2005 14:04:53
 Re: Oil spills and the law in reply to jdemaris, 04-12-2005 10:49:04
I have a very large drip pan collecting any oil when I change these filters, but thanks for the heads up. These were Fram filters from TSC (the only people open on Sunday) do you think bad o-rings?
Skip
jdemaris
04-12-2005 20:09:45
 Re: Oil spills and the law in reply to Skip in CT, 04-12-2005 14:04:53
I doubt it, but anything is possible.
