JD 420C steering clutch adjustment
mike from cny
04-12-2005 21:16:14
Hey all, I'm borrowing my boss's 420C for a little while to clear some brush and a spot for the pole barn. Its been working great, however turning right, to get the right track to lockup, I have to pull the lever with both hands. Wheres the adjustment for this? Thanks guys.
Bernie in MA
04-14-2005 18:04:25
 Re: JD 420C steering clutch adjustment in reply to mike from cny, 04-12-2005 21:16:14
Sounds more like the brake needs taking up. Under the little square cover on the top of the final drive is a bolt that hits the brake band lever when you pull the steering lever back. It may need to be turned in a little. There is also a slotted nut on the end of the band that can be tightened with a srewdriver if it isn't rusted too bad. Don't get things adjusted so tight the brake comes on before the fingers hit the throwout bearing (visible down inside the housing)
