piston rings
cape breton
04-14-2005 08:37:45
hi a buddy of mine has a 555 backhoe which he need a new piston for it broke of top ring. his pistons now have three rings on them he can get a new piston but it will have four rings some say this will decreas his power if he goes with the four ringed piston he figures he will have to replace his three pistons for the new type any one have any input thanks
Roy Suomi
04-16-2005 22:08:07
 Re: piston rings in reply to cape breton, 04-14-2005 08:37:45
Reminds me of a service call I went on about a year ago..A Ford 555-A backhoe. When I pulled up to the jobsite, I counted 11 starting fluid cans scattered on the ground around it...Wasn't a pretty sight.The fuel shut-off was plugged with crap.....The damage was done..... ...
jdemaris
04-15-2005 05:52:36
I don't know what make of machine you're asking about, Deere maybe? The only spec. that will affect the horsepower are the height of the top ring and/or the piston head standout. The simple existence of three rings or four rings, or coventional top ring or Keystone top ring makes no difference. You also need to match the total weight (piston with rings). The four of them need to weigh the same or you get a balance problem. Generally speaking, if there is one piston with a shattered top ring, the others are, at the least, going to have worn out top ring grooves. Don't know if it's a high-hours engine or too much ether got used. You ought to check it.
