Driving on black top
Farmer-Gene
09-20-2001 08:58:05
I've got a D-7 cat that I'm dozing out some fence lines with.In order to finish the job I have to cross a stream with steep banks and I'm afraid of getting hung up I've been thinking of driving down a black top road to get to the other side instead. I was told if it was below freezing out the black top wouldn't get tore up. has anyone tried this? How cold does it have to be?
digger
09-21-2001 09:40:12
 Re: driving on black top in reply to Farmer-Gene, 09-20-2001 08:58:05
plank it
Jeff Pack
09-21-2001 07:15:12
besides using planks, old tires work well.
thats what I use.
Max
09-20-2001 19:43:25
I wouldn't do it unless you want to replace the blacktop. I've seen companys that use the crawler to remove the asphalt and I don't think you'll be able to start tha ol'Cat when the temp gets low enough to travel. The other option is to have 4 friends lay down planks infront of you and other friends to pick up the planks behind you.
doug vose
09-20-2001 18:15:11
ive driviin a jd 420 down the road before without it leavin anything but small marks. it was about 80 degrees out, too. im not familiar with cats, and a d-7 probly wieghs a lot more than a 420...
