JD 350B Power Steering questions
Engine One Eigh
04-15-2005 19:29:31
Just purchased a JD 350B diesel dozer and have a couple questions about the power steering. Don't think mine is working, the levers travel a good 8-10" before turning the dozer. I pulled the seat and there seems to be lots of free play where the hydraulic units are mounted. Is this normal? Do you check the fluid with the dipstick located on the platform near your left heel? The level was fine but the fluid smelled more like motor oil then hydraulic fluid. thanks for the help
jdemaris
04-15-2005 20:33:37
 Re: JD 350B Power Steering questions in reply to Engine One Eight, 04-15-2005 19:29:31
The power steering cylinder mounts are always sloppy - what you see is probably normal. 350 and most 350Bs have a separate power-steering pump on the front of the engine. You might have to pull the hood off to fill the reservoir - it's hard to get to and usually empty. Later 350B and newer use pressure oil from the hydraulic reverser to feed the power-steering.
Engine One Eight
04-17-2005 18:42:45
 Re: JD 350B Power Steering questions in reply to jdemaris, 04-15-2005 20:33:37
Thanks for the help. My crawler must be a later 350B as I could not see the pump on the front or a reservoir under the hood. It has two places to check the oil on the platform.
John
jdemaris
04-17-2005 19:58:54
 Re: JD 350B Power Steering questions in reply to Engine One Eight, 04-17-2005 18:42:45
The two dipsticks on the floor/platform are for the hydraulic reverser and the gear transmission.
