case backhoe valve
stressfree
04-16-2005 03:09:07
put oil to attachment.boom section is leaking and i have to pull valve body off.what blows orings? book shows orings betweeen each section.they have a seal kit for the valvebody or can you buy singles?
Roy Suomi
04-16-2005 20:58:35
 Re: case backhoe valve in reply to stressfree, 04-16-2005 03:09:07
If your dealer is that bad , you should buy your own parts books and order the parts that you need instead of relying on an incompetent parts person. I find that if I order my parts by number, I have exactly what I need.. And if I screw up , Oh well, Life sucks then you die....
Roy Suomi
04-16-2005 21:01:45
 Re: case backhoe valve in reply to Roy Suomi, 04-16-2005 20:58:35
The usual cause of o-ring failure is someone took the valve apart and didn't torque the thru-bolts to the proper tightness....
stressfree
04-17-2005 06:34:54
 Re: case backhoe valve in reply to Roy Suomi, 04-16-2005 21:01:45
my parts book is case c-930.i picked out the parts by # when he looked at his screen oh that number was superseeded by yada,yada,if there is an aftermarket dist. out there id like a phone numder.
