case 450 2 spool valve fitting
stressfree
04-16-2005 03:20:55
my case dealer is useless,ordered all the wrong parts,yoey,anyway go to parts book and on the 2 valve section it shows a straight fitting d35401
for a pressure side hook up for the backhoe.its straght thread with oring but its lenght must block off something in the valve.anybody famialiar with this fitting.oh the loader control valve body.
Jean Claude marleau
04-17-2005 07:42:13
 Re: case 450 2 spool valve fitting in reply to stressfree, 04-16-2005 03:20:55
first of all there is a communication problem I guess with your partsmen and Case people I was working there for 37 years and when the company make a mistake and you show them in the book they refer to the ingineer blue print and see the part is not the same there is no bullshit about 10% re-stocking.I am pretty sure I have such a used fitting in stock, the number I guess was sub to D61251 . will check tomorrow. jcm
stressfree
04-17-2005 17:56:12
 Re: case 450 2 spool valve fitting in reply to Jean Claude marleau , 04-17-2005 07:42:13
my parts manual is c930.my number in the parts book is D-35401 fitting carryover backhoe models only.plus 2 orings,218-5010,and A-25590.
any ideas also how to track down my model backhoe with the serial numbers,model # wore off. oh my case 450 serial # 3031747 loader
Jean Claude marleau
04-16-2005 21:11:45
Yes i am familiar with this fitting but what is it that's wrong . this is a popular fitting it fit on all the Case loader valve either crawler or tractor. my e mail is jcmarleau@aol.com
stressfree
04-17-2005 06:28:47
 Re: case 450 2 spool valve fitting in reply to Jean Claude marleau , 04-16-2005 21:11:45
if you would do me a favor,where you get your case parts,get the new crossover number.that fitting came back as a 90 deg 3/8" oring bullet.all the fiiting were wrong,10% restocking charge.that fitting is 1" straight oring.
