Case D-450 Hydraulic Fluid
John Flippo
04-16-2005 13:02:42
What is the recommended hydraulic fluid for a Case D-450. Thanks in advance.
Phil H
04-22-2005 06:57:39
 Re: Case D-450 Hydraulic Fluid in reply to John Flippo, 04-16-2005 13:02:42
Hi John, I use the tch, in the trans. and regular hyd. fluid in the tank for the loader and hoe. If you don"t have a lot of leaks in the hyd. system then using one fluid would have to be the tch. It is more expensive but you can use it anywhere. Where as the hyd fluid is best used only, in the hyd system, like the loader, hoe, rippers, blade, etc. If there a lot of leaking ram seals, then it can get expensive replacing the hyd. with the tch, but like I said you can use the tch, anywhere.
John W. Flippo
04-17-2005 14:01:51
Thanks for all the help. This is my first CASE and although I am enjoying it, I have alot to learn.
Another thing, can you tell me where to look to check the transmission fluid?
Again, Thanks.
marlowe
04-17-2005 17:39:36
 Re: Case D-450 Hydraulic Fluid in reply to John W. Flippo, 04-17-2005 14:01:51
under the seat is the dippstick
Robert in W. Mi.
04-17-2005 08:52:09
I run TCH all through my 450, i'm told it has additives that makes the tranny last longer.
That's what my manual says to use in it too.
Robert
John Van Valkenburgh
04-16-2005 23:33:57
My Case dealer recommended Case Hy-Guard for the transmission and bucket hydraulics. He sells it for about the same as TCH. Apparently TCH is an older fluid.
John
1968 Case 450
marlowe
04-16-2005 14:59:31
CASE tch is whats recommended but if this machine is second hand more then likley they have been useing plane hyd. oil the only thing it's used for is to run the hyd. and not any trans or power shift. i use plane hyd. oil in the hyd. only and TCH in the power shift and trans
