t 340 has power one side only
clyde
04-17-2005 17:50:26
my friend was doing some light work with a t340 he just bought, the one side stoppped driving, he said he can't even get it on the trailer because it tends to turn. any ideas? what should we look for? where do you get parts for it? thanks for the help, clyde
PD Mechanical
04-18-2005 05:39:41
 Re: t 340 has power one side only in reply to clyde, 04-17-2005 17:50:26
third party image
You may have lost one of the linings on the brake. There is an adjustment on the side of the rear housing below the seat. It is a set screw with a large lock nut. You unlock the lock nut, pull the steering lever back and turn in the set screw a little at a time releasing the lever each time checking for free travel in the lever. Keep doing this until you have obtained roughly 2-3" of free travel measured at the tip of the lever. If you have to adjust it in a long way then you have probably lost a lining and it will then be running metal on metal. I would not reccomend running this way but this may help you get it on a trailer. You'll then have to get into the steering system to repair the problem. The adjustment procedure I have given is just a general adjustment to maybe get you on the trailer. You shoule get yourself a manual and make the proper adjustments according to the book. If you have any other questions feel free to email me directly and be sure to visit our website.
hector gemme
04-18-2005 02:27:21
HI I have some use parts for t340.HECTOR
