Case 350 - Spool Valve
Jon (IN)
04-19-2005 05:11:45
I have a Case 350 Track loader. Operates fine, but the spool valve shows visible leaking and has some noise when operating (sounds like air). The only problem I have noticed with the hydraulics, is that the bucket will not hold down pressure when I backdrag. It will roll when I use the lever, but will not hold it. Could this be a problem in the spool valve? How big of a job is it to rebuild the valve? And will I see much improvement in the operation of the loader?
Thanks,
Jon
J. Schwiebert
04-19-2005 19:30:56
 Re: Case 350 - Spool Valve in reply to Jon (IN), 04-19-2005 05:11:45
Do you have a casting number from the valve. I know we used to have some Case people in our Gresen classes. They also used some Commercial products too.
