CAT 910 problem
BSer
04-19-2005 16:13:03
I have a 910 that we use for cleanup/catchup at our boneyard. In the 3 years I"ve had it,it has always been slow to move first thing in the morning and after being shut off for a few moments. It"s gotten worse;having to sometimes restart it to get it to " pickup a prime" It pulls great,doesn"t build up heat and the oil and filter stay clean. We use 30w oil and have changed it several times. The pump gauge on the dash doesn"t work. We"d like to diagnos and repair. I"m looking for ideas.
John Van Valkenburgh
04-19-2005 20:08:45
 Re: CAT 910 problem in reply to BSer, 04-19-2005 16:13:03
I used to run a Cat 910 years ago. Your machine should not be acting sluggish when first started. I would suspect a clogged pickup tube in the hydraulic tank or a pinched line running from the hydraulic supply tank to the pump.
Best of luck,
John
1968 Case 450
