Replaced Fuel Filters, Now Won't Start
John Flippo
04-24-2005 19:21:27
I replaced the fuel filters on my Case 450. After that, it turned over but wouldn't start. Then it would not do anything at all, nothing. Is there some kind of reset to this thing?
Thanks again,
John
Leland
04-28-2005 07:36:17
 Re: Replaced Fuel Filters, Now Won't Start in reply to John Flippo, 04-24-2005 19:21:27
I usually just fill new filters up with tranny fluid cleans pump good after filter change.
ajk
04-25-2005 01:52:00
Some Case machines had a push button circuit breaker,have a good luck around the dash, it may have popped and needs pushing back in,the starter should nor fail that easy unless you kept it turning over for a long time and it overheated,it would smell real bad,have you got lights ect.
AJ
marlowe
04-25-2005 15:58:31
 Re: Replaced Fuel Filters, Now Won't Start in reply to ajk, 04-25-2005 01:52:00
bleed system and then bleed again got air in it NO reset just air in system
wilko
04-24-2005 20:25:28
I hate to be too basic here, but did you fill the filters with fuel and bleed the air out at the injector pump? Worst case, it would'nt start because of air in the line and then the starter burned out from cranking it over too long.
John Flippo
04-24-2005 20:32:12
 Re: Replaced Fuel Filters, Now Won't Start in reply to wilko, 04-24-2005 20:25:28
Thanks Wilko. Not too basic at all. I did not know to fill them with fuel nor did I know about bleeding air out of the injector pump. Not familiar with these tasks at all. Any additional help would be highly appreciated.
toeman
04-25-2005 05:22:07
 Re: Replaced Fuel Filters, Now Won't Start in reply to John Flippo, 04-24-2005 20:32:12
bleeding the fuel system is a must after you open the fuel system for any reason.
first look for a hand operated primer pump on the machine. it is most often found on the engine and is connected between the fuel tank and the filters. this pump may have a plunger or a lever on it. look closely for the lever, as they are not very big. next, open the bleed screw on top of the filter housing[s]. pump the lever untill fuel flows steadily from the bleed. next try to find any bleed screws on the pump, and bleed the air from the pump too.
next you will have to bleed the injectors.
loosen the injector fuel lines at the cylinder head, and crank the motor untill you see good fuel coming out[foamy fuel does"nt count].
tighten the injector lines and attempt to start the motor.
remember, cranking the starter too long will get it hot.
if you can"t touch the starter motor without asbestos fingers, its too hot.
try cranking it over, you should begin seeing smoke at the exhaust. no smoke means no fuel.
make sure that all fuel shut-off"s are on.
if this doesn"t help you, write me a note, and we will get to the bottom of it.
tony
John Flippo
04-25-2005 13:10:57
 Re: Replaced Fuel Filters, Now Won't Start in reply to toeman, 04-25-2005 05:22:07
Thanks for all the help. Got it running again. Also did the air bleeding.
