jd 450 clutch help!
andy newlon
04-29-2005 10:07:48
third party image
I finally got my dozer. Check out this link to see a little of what it went through getting here
Link
jdemaris
04-29-2005 12:17:12
 Re: jd 450 clutch help! in reply to andy newlon, 04-29-2005 10:07:48
Isn't that shaft drilled and tapped so you can thread a bolt into it? I think I've pulled stuck shafts out in 450s by either bolting a chain to it and pulling with something, or rigging a puller to it.
dsldr
05-08-2005 18:06:41
 Re: jd 450 clutch help! in reply to jdemaris, 04-29-2005 12:17:12
I believe on the 450"s you need to remove a plug above this quill shaft on the outer side of the tractor (just above the track) I think with a 3/4 drive ratchet and behind this plug you will find a set screw that sets the shaft to the gear. You may need to turn the sprocket to get the set screw to line up with the hole so you can remove it. I also believe there may be a ball under the set screw. Oncew this is removed, the shaft should slide right out. (If not a slide hammer will make short work of it.)
