Resealing hydraulic cylinders on a Case 450
Brian RB
04-30-2005 07:50:45
How hard is it to reseal or repack hydraulic cylinders on a Case 450 loader? I"m planning on doing all my cylinders because the loader has set for 10 years and all leak whether a little or a lot. I know I need an adjustable gland nut wrench. Would I be better of to let a repair shop reseal the cylinders?
NC Wayne
04-30-2005 20:16:55
 Re: Resealing hydraulic cylinders on a Case 450 in reply to Brian RB, 04-30-2005 07:50:45
Hey Brian, if you buy a gland wrench go ahead and spend the extra to get a quality one made by OTC. Thier in the $80 range but well worth it if you run into one of the glands that's expecially tight. I say this because they will stand up to the impact force of using a Swench with it to break the gland loose. I've done several cylinders in the past few months where the gland was too tight to get loose by hand. On the first one I didn't know if it would work, but it was worth trying to keep from having to pull the cylinder, so I put one of the offsets on my 3/4 drive Swench and used it. It took two pops and the gland broke loose and backed right out. If you don't know what a Swench is do a search and it'll come up in back discussions. Once you get you one you'll never know how you got along without it. Good luck.
ben brown
04-30-2005 18:56:42
i am a big user of after market parts except when it come to hy-cly. get the right seal from case save your self some time also the wrench is handey but like the other post have had to weld bar on glan nut and heat the cly not to hot. if you can find a herschel adams dealer www.herschel-adams.com they have the gland wrenches both large and small
just 580's
04-30-2005 20:15:35
 Re: Resealing hydraulic cylinders on a Case 450 in reply to ben brown, 04-30-2005 18:56:42
Interesting, does Case make their own seal kits? Will the dealer be able to get you the kits without disassembling the cylinders first?
After pondering these questions contact a good aftermarket parts supplier that specializes in Case construction & utility equipment. Go to Google and type in "Case 450 parts" and click on the first link that comes up.
marlowe
04-30-2005 15:24:40
easy to do don't get parts from case will cost a arm and leg call baum hydrulics 1-800-228-9222
stressfree
04-30-2005 17:38:57
 Re: Resealing hydraulic cylinders on a Case 450 in reply to marlowe, 04-30-2005 15:24:40
that bram have a web page?
marlowe
05-01-2005 04:56:40
 Re: Resealing hydraulic cylinders on a Case 450 in reply to stressfree, 04-30-2005 17:38:57
sure do www.baumhydraulics.com
gatractorman
04-30-2005 13:40:08
It's not hard to replace the seals and o-rings once you get into the cylinder, probably going to have a rather large nut or bolt to take off the end of the shaft when you get the cylinder apart, I have had Case cylinders that I had to weld a bar on the gland so I could hit it with a hammer to get it broke loose, most are not that bad but you do run into those occasionally.
