3rd valve for 920 cat loader
RLH
04-30-2005 14:33:30
Ive put a 4in1 bucket on my 920 before I tried to find a 3rd outlet now Im finding parts impossible to find does anybody have a plan two
MSM
04-30-2005 15:56:43
 Re: 3rd valve for 920 cat loader in reply to RLH, 04-30-2005 14:33:30
Possibly an electric/ hydraulic splitter plumbed into the feed lines for the curl circuit would do the trick. (One of the splitters that give you a second remote on a tractor around $700.)Plumb the inlet side of the splitter with the curl hoses from the loader, one outlet side out would be plumbed back to the curl hoses, the second outlet side plumbed to the 4in1. Your curl lever would work as it does now with the electric botton released, push the electric button and push/pull the curl lever and the 4in1 opens or closes.
RLH
05-01-2005 06:07:12
 Re: 3rd valve for 920 cat loader in reply to MSM, 04-30-2005 15:56:43
Thanks for your reply ive been told splitter valves can cause damage to pumps I cant see this as long as it has the gpm rating of the pump whats your thoughts ???
MSM
05-01-2005 08:15:11
 Re: 3rd valve for 920 cat loader in reply to RLH, 05-01-2005 06:07:12
There shouldn't be any problem as long as the splitter has enough capacity to match the flow of the curl circuit.The splitters I have used handle 2500+psi and 28-30 GPM flow. I have put them on large skid steers and numerous large farm tractors.The pressure on a 920 should be around 2200-2500 psi and I seriously doubt the flow requirements of the curl circuit would exceed 20-25 GPM. I am not certain if there are 24V splitters available, a 12V splitter could be wired into 1 battery with a fuse or circuit breaker to give you 12V.
RLH
05-01-2005 12:27:27
 Re: 3rd valve for 920 cat loader in reply to MSM, 05-01-2005 08:15:11
What brand do you like best ?where can I get one?I saw one that had to have pilot oil to shift it looked complicated are there pictures on web thanks
