350C Year and Value
shiner
05-02-2005 10:55:07
I am looking at a 350c dozer, SN 1136347, Model 4F3D (or 453D). Can anyone tell me what year model this is and what it"s approximate value is? Right brake does not work, has been idle for 2 years. Did this model come with a 6-way blade? Thanks, Gary
Doug in IL
05-04-2005 08:01:10
 Re: 350C Year and Value in reply to shiner, 05-02-2005 10:55:07
It looks like you have too many digits in the serial number you gave. It should have 5 or 6 digits.
shiner
05-04-2005 09:22:52
 Re: 350C Year and Value in reply to Doug in IL, 05-04-2005 08:01:10
Yes, I wrote the "T" as a 1. It should be 113634. The type is T4F3D. Do you have an idea of its' value or year of make?
Thanks
Doug in IL
05-04-2005 19:23:44
 Re: 350C Year and Value in reply to shiner, 05-04-2005 09:22:52
It is a 1970 model. It is a straight 350 with no B or C suffix.
shiner
05-04-2005 19:42:58
 Re: 350C Year and Value in reply to Doug in IL, 05-04-2005 19:23:44
Thanks, I appreciate it. Any idea of its value with 1200 hrs?
Gary Mckenzie
05-02-2005 16:04:12
I'm not sure, but I think with that model #(4F3D) it's a plain 350,not a 350C. If that's the case, it should be around '69 or '70. I'm sure someone will be along to help shortly.
jdemaris
05-02-2005 20:31:26
 Re: 350C Year and Value in reply to Gary Mckenzie, 05-02-2005 16:04:12
I can't help with the numbers, but either it has wet steering and brakes, or it does not. 350s, and 350Bs have dry steering and clutches, and the 350C is the first to have wet. A "C" series will have aluminum round bung-plugs on the top of the steering clutch housings for brake-adjuster access. Also, the C gear tranmsission won't have any reverse, whereas the older 350s have hydraulic reverse and gear reverse (if equipped with the hydraulic reverser). All the 350s were available with mechanical angle outside blade, 6-way hydraulic inside blade, or 6-way mechanical "logger's special" inside blade. I've also seen them with no blade, wide track pads, and three point hitch for farm work.
shiner
05-04-2005 19:45:14
 Re: 350C Year and Value in reply to jdemaris, 05-02-2005 20:31:26
I think you're right on everything. Any idea of its value, having 1200 hrs?
