john deer 1010 dozer
stumped
05-03-2005 15:50:31
was wondering how many horsepower a john deer 1010 two cylinder diesel has? and was wondering the value, it has a decent undercarriage, has trans problems says the main shaft bearing is wore in the case, has a six way blade. any ideas on what it is worth? any help is appreciated
jdemaris
05-03-2005 19:39:35
 Re: john deer 1010 dozer in reply to stumped, 05-03-2005 15:50:31
I think a two-cylinder John Deere 1010 diesel would be worth a lot if it really exists - I'd like to see one (but, don't think I will). Deere did make a couple of four cylinder 1010s - gas and diesel - but they are four cylinders. You sure you're not looking at a 440 with a 2 cylinder Detroit Diesel 2-53?
stumped
05-04-2005 04:26:38
 Re: john deer 1010 dozer in reply to jdemaris, 05-03-2005 19:39:35
it is a detroit 2 cyl but the guy said its a 1010. did the 440 come with six way blade? ill look for a serial # also where should i look for the serial# i found one on the blade. and another by the wobble control for the blade.
lavoy
05-04-2005 19:46:44
 Re: john deer 1010 dozer in reply to stumped, 05-04-2005 04:26:38
It is likely a 440ICD, if the blade is a power 6-way, it is a #64, if manual 6 way, then it is a #63.
440ICD serial number will be on the dash.
Lavoy
jdemaris
05-04-2005 06:12:12
1010s were not made with ANY two cylinder engines, but the 1010 four cylinder engines have the same bolt pattern as the older two cylinder gas engines - like the 420, 440, etc. I don't know if the Detroit 2-53 has the same bolt pattern as the two cylinder gas engine or not. Either way, if there exists a 1010 with a two cylinder engine, it is home-made. And yes, there were 440s with 6 way blades, also came on the older 420s - Deere called it a "high blade." What kind of transmission and/or reverser does the machine have? 1010 used the same hydraulic reverser as on the later 350. The 440 did NOT use it; it came with a totally different assembly that has wet mechancial "over-center" clutches, not hydraulic.
stumped
05-05-2005 18:11:24
 Re: john deer 1010 dozer in reply to jdemaris, 05-04-2005 06:12:12
it is a reverser i believe. all the shifting controls are on the dash panel. also the one on the left of the panel to make it go in reverse. i noticed the front idlers are loose with some slop in the bearings. the blade lifts clear up to the top of the hood. any idea on price guy said i could have it for $750.00
