TD18 international
Walter hudson
05-03-2005 18:34:23
hi im looking for a injection pump for a td18 or mabey some one that can rebuild my old one.
King of Obsolete
05-04-2005 04:52:10
 Re: TD18 international in reply to Walter hudson, 05-03-2005 18:34:23
head to redpower bb, there ar td-18 there.
Link
thansk
www.kingofobsolete.ca
hector gemme
05-04-2005 01:31:42
HI I have a td18 injection pump and more. SAND ME A É-MAIL.HECTOR
walter hudson
05-06-2005 22:26:28
 Re: TD18 international in reply to hector gemme, 05-04-2005 01:31:42
Hi Hector how much do you want for the pump.
hector gemme
05-07-2005 01:44:54
 Re: TD18 international in reply to walter hudson, 05-06-2005 22:26:28
HI I need $300.00 for use td18 fuel pump+shipping.SEND ME A É-MAIL.HECTOR
walter hudson
05-09-2005 15:26:20
 Re: TD18 international in reply to hector gemme, 05-07-2005 01:44:54
Hi where are you located? I am in coldwater Mississippi. Whould the pump that you have need rebuilt.
hector gemme
05-09-2005 15:50:46
 Re: TD18 international in reply to walter hudson, 05-09-2005 15:26:20
HI I just demolish 2 week pass but the motor whas stuckand the pump turne oke but I dont know if she is perfect.
walter hudson
05-14-2005 10:07:56
 Re: TD18 international in reply to hector gemme, 05-09-2005 15:50:46
Hi if i buy the pump from you how far away are you i am in mississippi do you have any good used rail track
hector gemme
05-14-2005 12:24:23
 Re: TD18 international in reply to walter hudson, 05-14-2005 10:07:56
HI I am from Montreal CANADA and I have a use set rail track and I NEED $700.00 FOB. HECTOR
walter
05-22-2005 20:10:24
 Re: TD18 international in reply to hector gemme, 05-14-2005 12:24:23
Hi I need a part for the hydraulic pump that operates the blade. Its a small splicing gear about 1 1/2 long it has 6 teeth on the inside and the outside. It cuples the shaft from the pump to the shaft from the motor. TD14 & TD18 have the same splicing gear. Do you have one and how much do you want for it. Thanks
hector gemme
05-23-2005 09:05:14
 Re: TD18 international in reply to walter, 05-22-2005 20:10:24
HI I have the cuppling and I NEED $20.00 WHIT SHIPPING .HECTOR
walter hudson
05-23-2005 20:36:15
 Re: TD18 international in reply to hector gemme, 05-23-2005 09:05:14
Hi do you have a good shaft that connects the little splicing gear to the pump. It comes out of the end of the crankshaft of the TD18
how much do you want for the two pieces together. Thanks
walter hudson
05-25-2005 21:40:16
 Re: TD18 international in reply to walter hudson, 05-23-2005 20:36:15
Hi what is your email address? How much will the splicing gear cost to have it shipped to coldwater ms.
