john deere 450b track clutch
Nickr9
05-04-2005 12:34:16
hi all, i am from the uk and am doing up a 450b, love the machine but it won"t turn to the left, the brake works but it won"t turn, is it a case of adjustment as there is no restriction on the lever until the brake engages or something more serious?
nickr9
05-04-2005 12:42:07
 Re: john deere 450b track clutch in reply to Nickr9, 05-04-2005 12:34:16
plus does anyone out there have an owners manual for this machine as these machines are rare over here
dennisJ
05-04-2005 13:38:38
 Re: john deere 450b track clutch in reply to nickr9, 05-04-2005 12:42:07
There is a definite adjustment procedure for the brake and clutch assembly. The adjustment procedure is pretty much the same for all the small machines. Basically, you need to set things up so that the first part of the lever movement disengages the clutch. The last part of the lever movement applies the braking action. If the clutch does not disengage, the axle is still being driven and it is unlikely that the brake will work.
We have a manual for an old 420 somewhere in our service library. If you send me your email address, I will send you the procedure from the book.
nickr9
01-06-2006 02:49:10
 Re: john deere 450b track clutch in reply to dennisJ, 05-04-2005 13:38:38
that would be great, email is nickashby9@aol.com cheers
John Wells
07-23-2005 09:59:30
Were you able to find the info on that clutch adjust? We are working on a side hill that gets slippery as hell when you don't have a clutch/brake available.
My email is liquidsands@msn.com
I would appreciate amything you could send as procedure and adjustment specs for the JD 450B crawler (1974 year).
Tahnks,
John Wells
nickr9
01-06-2006 02:51:46
 Re: john deere 450b track clutch in reply to John Wells, 07-23-2005 09:59:30
i have sorted my clutch, it turns out it was seized up, i know how to adjust it too, if you still need help drop me a line on nickashby9@aol.com cheers
nickr9
05-14-2005 00:01:48
If you could show me how to adjust clutch and brake or give me an idea of where to start i should be ok, i don.t know the free play gaps etc? many thanks
