International B100 Drott, How Do I Remove The Clut
WILL_WADE
05-05-2005 01:44:52
I have taken the floor covers off, taken the bolts that secure the clutch in, but I can not find away of takeing the drive shaft out to allow the clutch to lift free.
Help would be well apreciated..Cheers!
ajk
05-05-2005 07:26:43
 Re: International B100 Drott, How Do I Remove The in reply to WILL_WADE, 05-05-2005 01:44:52
The drive shaft comes out with the assembly,take the grease nipple out of the end of the shaft,and if you got all the other bits out of the way including the cross shaft that operates the release bearing yoke, slide the drive shaft back and lift the assembly out in one piece,note the direction the disc is faced,on installing you need a piece of string to hold the centre plate up while you get the shaft to into the pilot bearing.very tight squeeze either way.
