TD6 injection pump questions
Dennis Freytag
05-10-2005 18:26:28
Just put the original engine back in my TD6 after the WD6 engine I had in it opened up an old crack in the block. When I started it up it ran great on gas but the A injection pump was not working. rack was frozen and distributor block rusty. Plenty of pressure on fuel gage. So I took the distributer block and barrel out of the WD6 injection pump (also an A) and put it in the TD6 thinking I would not have to retime it. When I started it back up on gas, it blew out a steady cloud of diesel this time. I tried adjusting the control arm, but that was not the problem. When I change over to diesel it still puts out a steady cloud and seems to run at too high rpms ( no way to test) It also does not respond to the throttle and seems to run at the one speed, but possibly speeds up a little. Is there an adjustment that can be made underneath the oil filler? Thanks
