gm 2-53
arnie1968
05-11-2005 14:15:38
i have a 440 jd with a gm 2-53 in it..it holds 40 psi oil pressure all the time, older engine.
I also have 1 in a 435 jd. i rebuilt it last year. it only holds 35 or so and nearly nothing at an idle..i put all new bearings and turned all the shafts, checked them when i installed them etc. I didn't replace the oil pump..it lookd ok...i cleaned it up and re-intalled..it takes it a bit to pick up pressure when staring as well..any ideas
thanks kevin
JD dozer mike
05-18-2005 10:52:20
 Re: gm 2-53 in reply to arnie1968, 05-11-2005 14:15:38
check your pressure line , no leaks? probably need to rebuild sump pump.
BKahler
05-11-2005 14:55:54
Kevin,
You might want to post your question on the John Deere forum or the crawlers forum on this site.
Also check out the John Deere Crawlers website, very helpful.
Brad
PS, I also own a JD 440ICD but don't have it home or running as yet.
