Same problem
Case450
05-11-2005 16:58:40
My case 450 is still buggering up. It goes good for about a half hour than loses all power. The motor still runs the same (no lull or anything) there is just no push to the machine. I have changed all the filters (hydraulic/air/etc.) and still no difference. There are no gauges that work on the machine so pressures are unknown. Also, there is a hydraulic line that runs from a filter under the operators right arm (in drivers seat), under the seat and into a housing with the driveshaft in it as well. What is that? I have a feeling my problem might be in there somewheres...any ideas?
seann
05-11-2005 20:32:15
 Re: Same problem in reply to Case450, 05-11-2005 16:58:40
I thought from your last post that the filters were severely gunked up. And then after replacing the filters it ran like a top and everything was fine? If that's the case it may be that the oil is heavily contaminated/dirty and the new filters have been quickly plugged up again. Just a guess, but if it was suddenly running fine for awhile after you replaced the filters, but now is behaving the same way, I'd have another look at the filters and strongly consider replacing the oil if need be. Plus I'd definitely get a working transmission pressure gage on it too. You don't want to run the machine with low transmission oil pressure, plus it would really help to diagnose what your problem might be.
