case 350 id
Kevin Brooks
05-12-2005 12:34:06
My in-laws have a Case 350. It is a crawler/loader. I would like to find the appropriate service manual for this but am confused when I see models listed such as 350b. How can I tell what model and series this Case 350 is and is a 350b service manual appropriate?
Doug in IL
05-12-2005 17:30:38
 Re: case 350 id in reply to Kevin Brooks, 05-12-2005 12:34:06
If you can find and post the serial numer here, I can tell you what series it is.
Kevin Brooks
05-14-2005 17:58:07
 Re: case 350 id in reply to Doug in IL, 05-12-2005 17:30:38
The crawler S/N is 3042739. It has a loader attached with a ballast on the rear as counter-weight. The loader S/N is 4198722.
Would a service manual that indicates 305B be appropriate? I need to service the tracks, driveline, hydraulics - including pistons/cylinders, gas tank. Sounds like just about everything sort of the engine, huh? By the way, the machine does still work, just a little rough when the going gets tough.
Any help much appreciated.
Doug in IL
05-15-2005 17:09:00
 Re: case 350 id in reply to Kevin Brooks, 05-14-2005 17:58:07
It is a 1970 350. In fact it is avery early one, the 38th 350 built. It is a straight 350. No B or C suffix. I can't help with your other questions, I know a little about some Cats, but nothing on the Case.
Kevin Brooks
05-16-2005 08:58:13
 Re: case 350 id in reply to Doug in IL, 05-15-2005 17:09:00
Thanks, Doug. Appreciated your replying to my question.
