JD 350B Side Panel Questions
Engine One Eigh
05-14-2005 20:39:33
I don"t have side panels (engine covers) for my 350B and recently got some brush jammed up near the fuel injector so guess I"d better build some panels! How thick were the originals? Did they have holes punched in the entire panel? What side holes? Any other suggestions? Anyone have a pattern to build the instrument panel cover that was an option?
Thanks
John
Rob J
05-16-2005 12:22:38
 Re: JD 350B Side Panel Questions in reply to Engine One Eight, 05-14-2005 20:39:33
check out www.deere.com then go to the parts section.
I found this picture..
Picture link
CloidR
05-15-2005 07:14:19
I bought a 350 with the right side pannel only it has the sliding door for dip stick access its made from 3/16" plate I duplicated the pattern for the left side and made it. Forget about the holes and just leave 3" between the cowling and the top of the your new covers there are 2 tangs on the inside of the nose cowl just make sure your cover ingages the top one. You might have to make the foward end full height then slope it down at 45 deg. to get your 3" air gap
CloidR
05-15-2005 07:13:53
jdemaris
05-15-2005 06:02:38
The side covers changed over the years. Some were perforated, and some were not. They did not come all the way up, and one side had a sliding door thay opened sideways, so you could check and/or add engine oil.
2x4
05-14-2005 22:30:11
practically impossible to duplicate. Originals were 3/8ths plate with a hundred slots cut in them. I would take some old heavy screen or other side panels & cut them to fit, or buy from salvage yard.
