Bill, A complete rebuild is a good idea if you are experiencing lower oil pressures at hot idle or if you otherwise suspect that the mains need attention. An out-of-frame will also allow you acess to the rear main seal. In theory you could unbolt the torque converter and get to the rear main seal but if you have to unbolt the TC you might as well pull the engine to get easier access. I'm rebuilding a 188 in my 450 and so I can't tell you for sure how easy it is to pull the engine but I'd imagine your machine is similar. There are 3 motor mounts (one front center and two on either side in the back). These unbolt easily. If weight is a problem you might consider removing the head first. You will undo the fuel injection lines, radiator hoses, wires to the starter and generator, and you will have to undo the lines running to the charge pump and "accessory hydraulic" pump. The 188 is not a difficult engine to rebuild. I'm in the early stages of re-assembly with the new sleeves and pistons just installed. As I mentioned in an earlier post the hot oil pressure was very good and so I've left the mains alone. The con rod bearings looked good too but I'm installing new ones for the heck of it. It appears that the crank has never been turned. Had it not been for a broken top compression ring in the #2 cylinder it might have run for a long time yet. I made my own cylinder sleeve puller. I ment to bring in a picture of it to post. I was able to work the injectors out with a slide hammer type puller and a little tool that is used with my air cutting wheel. I was lucky in that my injectors came out fairly easily. I'm told that they sometimes can really stick and can be difficult to remove even with a "factory" tool. In regards to working on the engine, I found it much easier once I removed the radiator and front cowling from the machine. Again I don't know if your machine is similar but I'll bet it is. I also had the foresight to run the machine up on two big 6x6 square sections of wood to allow a little more clearance under the machine. It's nice to be able to use a creeper. Drop me an email if there is anything I can answer for you. John 1968 Case 450
