Mustang Skid loader hydro problems
Bryan in Iowa
05-17-2005 07:19:07
I have a small 310 mustang.One side does not have as much power as the other, forward , or reverse . Had pumps rebuilt years ago ,,still had same problem. Drive motors are not leaking that i can see. Is there a pressure adjustment on charge pumps , and how is it made ? thanks Bryan
gatractorman
05-18-2005 16:21:27
 Re: Mustang Skid loader hydro problems in reply to Bryan in Iowa , 05-17-2005 07:19:07
Well if no one else is going to try I'll take a stab at it, first a disclaimer, I have worked on exactly 1 Mustang skid-steer and it wasn't a 310, but usually skid-steers pretty much operate on the same principal from brand to brand, you have an engine that turns some pumps that in turn makes the drive motors operate. Machines that I am familiar with have only 1 charge pump that supplies oil to both drive pumps and the pressure from it is not adjustable. Check the linkage on the side that is weak to make sure it is pushing and pulling the pump lever as far as the other side is. If I understand correctly it was acting this way before and after a pump overhaul? Was the drive pumps and motors both done at this time?
bryan in iowa
05-19-2005 07:52:37
 Re: Mustang Skid loader hydro problems in reply to gatractorman, 05-18-2005 16:21:27
Drive motors were checked out some time after pumps were rebuilt. I did have a seal leaking in right one, replaced that . Linkages are adjusted so getting full travel . Going to try to check charge pressure on both pumps tonight .
thanks Bryan
