1845C wheel bearing replacement
kyhayman
05-17-2005 19:28:48
Seems that with a load on the inside of my right front rim is rubbing the cast bearing holder. Im guessing a wheel bearing? Anyone have any thoughts and any idea how big a job it is to change? Friend of mine has a Gehl and says its an all day job on his.
gatractorman
05-18-2005 04:01:29
 Re: 1845C wheel bearing replacement in reply to kyhayman, 05-17-2005 19:28:48
Well they are a little aggrivating, the easy part it removing the tire and the nuts that hold the drive assy. to the side of the machine. Then you have to work down thru oblong covers that are above where each wheel drive sprocket would be, you will be going after a rather large and stubborn cotter pin and a large nut that holds the sprocket on the drive axle, after both these are off the housing and axle assembly should come off.
kyhayman
05-18-2005 19:39:34
 Re: 1845C wheel bearing replacement in reply to gatractorman, 05-18-2005 04:01:29
Today I got good news and bad news on it. Pulled the wheel. Good news is the wheel bearings are fine. Bad news is the the foam filled tire has a ripped rim, 90% torn off on the inside.
