3414 international backhoe
td9
05-22-2005 17:49:55
Just traded for a international backhoe I belive is a 3414, It seems to have the same motor, tranny, and rear end as my B-275. Problem is the guy took most of the hydaulic lines for the backhoe and loader loose and switched them around. I would like to put themback like they are supposed to be. Has anyone ever owned one of these things or know what levers are for what clyinders and which way the cylinder should move in relation to the levers?
Thanks for any info you can give.
Roy Suomi
05-26-2005 20:32:37
 Re: 3414 international backhoe in reply to td9, 05-22-2005 17:49:55
4 lever controls ?? if so, far left lever works boom[ pull back to raise boom, push to lower boom] near left lever works crowd [ pull - dipperstick comes to you, push -dipperstick goes away from you.Far right is swing , push it goes to left, Pull , it goes right. Near right lever controls bucket, pull- bucket comes to you, Push -bucket goes out....
