TD 14 Clutches
Paul800
05-22-2005 19:25:05
The brakes on TD 14 are frozen up removed top and bottom covers. Removed cotter pins and removed the arms that engage the clutches and bolts from ring and pinion side that slides in and pushes on the clutchs. See some 3/4 bolts that have saftety wire thru them but don"t see how that would assist in removing clutches. Anyone know where to find overhaul manual?
hector gemme
05-23-2005 09:53:17
 Re: TD 14 Clutches in reply to Paul800, 05-22-2005 19:25:05
HI You have to cut the lockwire on the six cap screws which the two-moon shaft coupling retainers. Remove the three cap screws from each retener and pull the coupling in cage cap. I have some use td 14 parts. HECTOR
