420 steering clutch teardown
doug vose
09-27-2001 17:16:07
how would one go about taking apart the steering clutch(s) in a 420C.
I take that it is the steering clutches that need repair because it has been sitting outside for a few years with no movement, and when i tried to turn it wouldn't.
Thanks for any help. Doug vose
Harvey
09-27-2001 22:12:25
 Re: 420 steering clutch teardown in reply to doug vose, 09-27-2001 17:16:07
I have just completed overhauling the right steering clutch on my 420c. Before you tear it down are you sure the clutches are in need of repair? What you are describing sounds like the clutches are stuck- that is they have rusted together and do not disengage when the lever is pulled. My unit had sat for a long period of time during the repair (~2years) and when i first started it I could not engage the transmission with the engine running.(the main clutch plates were stuck to each other. I was able to loosen by putting in gear with engine off and then engaging the starter (start switch off). The starter actually tried to move the tractor. After several tries the clutches separated. With the main clutch working I was able to work the steering clutches.
The process of knockdown and repair is covered in John Deere's publication # sm2019
