Where's the fluid?
Case450
05-26-2005 08:55:23
I am working under my '67 Case 450 Crawler loader. There is a hose that runs from a filter beside the hydraulic under the drivers right arm as sitting in the machine to the torque converter. That hose has fluid in it. There is another hose that runs from the bottom of the torque converter to the rear drive housing. That hose has NO fluid in it. What could be causing the blockage? Any ideas anyone?
Case450
05-26-2005 11:51:49
 Re: Where's the fluid? in reply to Case450, 05-26-2005 08:55:23
I took out the bolt on the torque converter that is beside the hose that runs to the rear drive. When I did a spring with a metal cap or hat on it fell out. When those fell out fluid came out of the hose hole. I take it that is supposed to move when the machine is hot or something to let the pressure build up or what? How does this work? What do I do?
