IH/ T-340 LOADER, NEED FINAL DRIVE HOUSINGS AND SP
tony forman
06-01-2005 00:04:42
HI I AM WORKING ON A T340 LOADER FOR A FRIEND,SPROCKETS ARE BAD AND THE BEARINGS SEEMED TO BE IN OK CONDITION(SIZE WISE) BUT THEY SLOPPED AROUND IN THE HOUSING LIKE A QUARTER INCH EACH WAY WHEN I MOVED THEM AROUND. SO I FIGURE I NEED TO LOCATE THE HOUSINGS FROM A TRACTOR SALVAGE YARD OR ANYONE THAT MAY HAVE A DONOR CHASSIS. ANY LINKS OR INFO WOULD BE GREATLY APPRECIATED. WE ARE LOCATED IN SOUTH WESTERN PENNSYLVANIA
tony forman
06-13-2005 00:43:21
 Re: IH/ T-340 LOADER, NEED FINAL DRIVE HOUSINGS AN in reply to tony forman, 06-01-2005 00:04:42
HI AGAIN,UPON COMPLETE REMOVAL OF THE CARRIER HOUSING I FOUND OUT THAT THERE ARE BEARING RACES ON THE SPROCKET SHAFT OUTER BEARINGS(THE PARTS DIAGRAM IN THE SERVICE MANUAL DID NOT SHOW THEM) THIS LEAD ME TO BELEIVE THAT THE HOUSINGS WERE TRASHED, BUT NOW ALL I HAVE TO DO IS GET THE BEARINGS AND RACES. BUT I STILL DO NEED THE ONE DRIVE SPROCKET.
hector gemme
06-01-2005 01:01:27
HI I have some parts for 340 do you need the outer or the inner housing final drive.HECTOR
tony forman
06-01-2005 23:27:24
 Re: IH/ T-340 LOADER, NEED FINAL DRIVE HOUSINGS AN in reply to hector gemme, 06-01-2005 01:01:27
they would be the "sprocket drive carrier" as called by the factory manuals. also need at least one drive sprocket.
hector gemme
06-02-2005 10:17:21
 Re: IH/ T-340 LOADER, NEED FINAL DRIVE HOUSINGS AN in reply to tony forman, 06-01-2005 23:27:24
HI I have a sprocket drive 25teet part number 636744r1. HECTOR
tony forman
06-02-2005 21:01:10
 Re: IH/ T-340 LOADER, NEED FINAL DRIVE HOUSINGS AN in reply to hector gemme, 06-02-2005 10:17:21
okay how much would you like for them or it. is it just the sprocket? or do you have the housings also? where are you located? if you want you can email me directly.
hector gemme
06-03-2005 02:05:31
 Re: IH/ T-340 LOADER, NEED FINAL DRIVE HOUSINGS AN in reply to tony forman, 06-02-2005 21:01:10
HI I need $75.00 F.O.B. for sprocket a I HAVE THE HOUSING FINAL DRIVE.I AM FROM MONTREAL AREA CANADA .HECTOR
tony forman
06-05-2005 22:10:22
 Re: IH/ T-340 LOADER, NEED FINAL DRIVE HOUSINGS AN in reply to hector gemme, 06-03-2005 02:05:31
okay hector sounds great now i need a price on the housings for both sides and if you have both sprockets i would like to purchase them also. and is there any way that you can calculate the shipping charges(estimate the weight ) i figure that the cheapest way would be to truck ship them.
hector gemme
06-06-2005 02:40:47
 Re: IH/ T-340 LOADER, NEED FINAL DRIVE HOUSINGS AN in reply to tony forman, 06-05-2005 22:10:22
HI I check my housing final drive and the part number for the inner housing is 635050r2 and the outer is 635051r2 and for the bolt I check this morning and for the shipping price I see UPS WHAT PRICE.
