JD350B TRACK ADJUSTER
DOUG IN WASH.
06-03-2005 10:20:55
GETTING READY TO ADJUST THE TRACKS. ON ONE SIDE IT HAS THE NORMAL GREASE FITTING AND THE PREASURE RELIEF FITTING. THE OTHER SIDE HAS ONLY THE GREASE FITTING AND NO PREASURE RELIEF FITTING. HAS ENYONE EVER SEEN THIS BEFORE??
JD dozer mike
06-03-2005 12:41:33
 Re: JD350B TRACK ADJUSTER in reply to DOUG IN WASH., 06-03-2005 10:20:55
that or, someone brazed the hole shut , or the relief is on the under side because it is a universal part.
Rob in Yukon
06-03-2005 12:18:07
I've seen something similar on other machines. The relief in those cases was a groove along the length of the threads that let grease out slowly as the fitting was backed out.
