I am rebuilding a CASE 310D crawler loader. It has the under carriage suspended on springs and there is a lot of wear on all the moving components on that system.I've looked at several newer models and brands of dozers and found that the under carriage is rigid usually attached in the front and back from each side of the machine. I've been considering making the undercarriage non-movable on my crawler and eliminate the leaf springs that it has. The logic is that if it can be done for the the newly manufactured dozers then why not on my older one? It would eliminate part and wear points. Also, since this is a loader, the varying weight on the front causes the crawler to nose-dive and puts the strain on the moving suspension. There are some 3/4" diameter holes already through the undercarriage's matching plates. It looks that I can raise/lower the crawler's front to align the holes and intall some grade 8 bolts in them. My question is: Will this hinder some way the usefullness or steering of my crawler? I know that the original idea for the suspension was for track compliance to the surface, but does it help that much? What's your experience and opinion on this? Ken McWilliams Dayton, OH
