John Deere 420C - Dozer Blade Won't Stay Up
Woodsman
06-05-2005 04:36:53
I have a '56 John Deere 420C, with a No. 62 dozer blade. The blade tends to drop down when in the up position. Does this sound more like a cylinder or control value issue? Any suggestions of how to isolate and troubleshoot the problem? Thanks.
Lavoy
06-05-2005 13:33:45
 Re: John Deere 420C - Dozer Blade Won't Stay Up in reply to Woodsman, 06-05-2005 04:36:53
Lift the blade up and hold it with a jack or something. Remove both hoses from the cylinder and put plugs in. Take the jack out from under the blade, and see if it settles. If it does, it is the cylinder, if it does not, it is the valve.
Lavoy
Bernie in MA
06-06-2005 17:33:46
 Re: John Deere 420C - Dozer Blade Won't Stay Up in reply to Lavoy, 06-05-2005 13:33:45
When mine wouldn't stay up I found the ripped cup in the cylinder by the gurgling sound it made as the blade sunk down. I emptied an old style oil can, held the tip on the cylinder and the bottom against my ear.
Woodsman
06-05-2005 15:41:29
Thanks. I check it out.
