rusty gas tank
jpb04619
06-06-2005 05:56:14
hi, my crawler [57 case 310] is almost ready to use...i guess its time to replace the quart milk bottle i've been using as a gas tank...problem is , the tractor sat for about ten years and i did find water in the gas tank....any one have any suggestions on how to remove the heavy scale/rust from the inside of the tank....sandblasting will look after the outside....john b
case poor in pa
06-08-2005 17:05:34
 Re: rusty gas tank in reply to jpb04619, 06-06-2005 05:56:14
jp did you happen to replace the spockets? if you did where did you find them? i need a couple good ones. also you can put some water and some nuts and bolts in the tank. strap it to a wheel of a tractor somehow and ride up and down the hill...ive done that with reguar tractor tanks.. mite be hard with a dozer tank tho.....
jpb04619
06-13-2005 16:39:51
 Re: rusty gas tank in reply to case poor in pa, 06-08-2005 17:05:34
thanks for the replies,guys....no , i didn't replace sprockets but if i did i would contact ed at crawler heaven for them...john b
Capt. Zorro
06-06-2005 12:46:39
Take it to a radiator shop and have them drop it in their tank over the weekend. Eastwood has a gas tank sealer that I've used on my old cars that seems to work good.
