450 undercarriage question
Jim U
06-06-2005 17:38:25
I noticed a rub mark on the inside of the track out board side of the rail. Could this be a warn roller or something else that I should be concerned with ? Also is there a way to alin the track,my left one hits the pin on the loader arm and takes out the snap ring?
Roy Suomi
06-06-2005 20:26:48
 Re: 450 undercarriage question in reply to Jim U, 06-06-2005 17:38:25
Rub marks as high as the pin indicate badly worn bottom rollers.. As far as the track taking out the loader bucket linkage snapring.. Man that track frame is loose. Start to look at the front crossbar bushings and bolts. Sometimes you can replace the bushings with new to help align the track frame . Some grinding will be needed at the bottom of bushings to tighten the trackframe to the crossbar. There is supposed to be some movement at that contact point, but just enough to move without slopping around. I've also welded the hole I.D. to get the slop reduced. Finally, I've had to replace the crossbar with a ridgid mount crossbar. These don't use bushings at all. These were used on later model 450's..
