d-2 stuck lever
bobby worley
06-08-2005 16:07:18
hi, i have a 1940 caterpillar d-2.the lever that you engage for the pony motor to start the diesel is stuck in the engaged postion.any ideas on how to get it released?p.s. machine has been setting for years. thanks.
ksb
06-10-2005 23:06:08
 Re: d-2 stuck levera in reply to bobby worley, 06-08-2005 16:07:18
Bob, Sounds like your pinion is locked up, you will properly have to release the dogs that skip has mentioned below. What ever you done in releasing them is do NOT get your fingers in here you could lose the end off one, true story.
I would think about taken it out and cleaning it up and maybe even repairing it if need. They general don’t give to much trouble.
Skip in CT
06-09-2005 05:47:30
 Re: d-2 stuck lever in reply to bobby worley, 06-08-2005 16:07:18
The pinion is released by centrifical force when the diesel is running so you have to squeese the springs to make the dogs move to relese them. There was a post on ACMOC.ORG not too long ago where someone altered a pair of pliers that would fit into an opening and release the pinion. It was a slick tool and easy to make if you have a welder. Good luck.
Skip in CT
hector gemme
06-08-2005 17:12:09
HI Did you check oil in small transmission,their a plug lever on transmission side and on top a small plate whit 2 screw 9/16 you can see inside.I have some use d2 parts.HECTOR
