BOBCAT 743B STEERING
743b shade tree
06-14-2005 17:24:23
Just aquired a Bobcat 743b that has steering problems. Right foward motion comes and goes. the hydraulics sound like they are bypassing when it stops steering. The steering lever linkage seems to be ok. Where do you check the pump pressure on this machine? I have ordered a service manual - not here yet. Any help would be appreciated.
gatractorman
06-17-2005 18:37:48
 Re: BOBCAT 743B STEERING in reply to 743b shade tree, 06-14-2005 17:24:23
Ok I dont understand all I know about this, do the bucket hydraulics stop working when the steering stops? You only lose forward on one side? Reverse works on that side, fwd/rev works on the other side? Bucket hydraulic pressure is usually checked with the auxillary hyd. fittings located down the left side boom arm, they look like large air hose quick connect fittings. PSI should be in the neighborhood of 2150. The only way I know to check the hydrostatic pump psi is to deadhead off the pump I cant remember how Bobcat recommends to check hydro pump psi.
