D2 CAT Oil Pressure adjustment question
Bob Johns
06-15-2005 16:45:54
I have an early model (1938) D2 with very low oil pressure (also very few hours on the clock). I have seen something in one of the books about adjusting the oil pressure on thse old CATS by turning a knob that is found on the bottom (side) of the oil-pump. However, nothing I have read says anything about "how much" I need to trun the thing. I don't want to do something that may cause me even more problems. Is there any suggested amount that it should be turned?
Thanks much for any advice.
thehickdaddy
06-18-2005 01:29:47
 Re: D2 CAT Oil Pressure adjustment question in reply to Bob Johns, 06-15-2005 16:45:54
well, experience would just say to turn the knob clockwise, or tighter, a quarter turn or so and then start it and look at your oil pressure, if it went up 3 lbs, crank it some more, if it pegs the gauge, which is highly unlikely if you tighten in small increments, then loosen a little. just play with it, you wont break anything if you are ginger with it and move things in small increments. have fun troubleshooting. thehickdaddy
Bob Johns
06-20-2005 16:04:35
 Re: D2 CAT Oil Pressure adjustment question in reply to thehickdaddy, 06-18-2005 01:29:47
Hey Pard, thanks for the input on the D2 oil pressure adjustment. I'll give the quarter-turn at a time suggestion a try and see what happens. Wonder what pressure they ran at when new? 30 probably ain't bad?
