500 IH LOADER
FLYBOY
06-15-2005 19:40:39
I have a 500 IH loader that the right side will not pull at all. If someone has any ideal what the problem is all help would be great.
woodsman
06-16-2005 16:31:37
 Re: 500 IH LOADER in reply to FLYBOY, 06-15-2005 19:40:39
Sounds like the clutch is worn, did this happen suddenly or over time? First you need to adjust the clutches through the top plates. Get a manual if you can.
If all this fails it may be worn out, the wear tolerance on these plates is very small. i can help you with info on taking it apart if you have to go that far.
Not hard, just time consuming.
hector gemme
06-16-2005 03:04:25
HI Did you adjust that stering cluch if yes you have to take it off and look where is the probleme .
Lee Wv
06-15-2005 20:27:13
If it is like the only 500c I was ever into,it could be the splines in the steering clutch hub.
