anybody change brakes on a case 450
stressfree
06-16-2005 01:09:15
any tips i have the shop manual always tricks.
John Van Valkenburgh
06-23-2005 00:58:27
 Re: anybody change brakes on a case 450 in reply to stressfree, 06-16-2005 01:09:15
This was the first thing I had to do to my 450 loader. The brakes were sticking on and would heat up.
The manual calls for you to pull the entire brake assembly out in one piece. I would not do that. The left hand side assy would not clear and I had to cut the transmission hi/lo lever bracket.
Here's what I recommend:
Each brake assy is held in place on the transmission housing by 4 nuts. Leave these on for now. On the face of the brake assy you will see 3 or 4 bolts. Take these out first and remove the face of the brake chamber. Removing the face of the chamber first gives you the extra working room you are going to need. After doing this you can remove the 4 nuts which hold the chamber to the transmission and pull it straight out.
There are likely to be some shims on the back of the chamber where it fits to the transmission housing.
Once the chambers are off you can take them apart like the manual shows.
Best of luck,
John
1968 Case 450
mud
06-19-2005 18:34:38
Say Stress, Is your machine a dozer or loader?
We've used our loader without brakes for years. Use the bucket to stop us. You must have hills up are your place.
stressfree
06-20-2005 16:55:51
 Re: anybody change brakes on a case 450 in reply to mud, 06-19-2005 18:34:38
hey mud how ya been.my 450 is a loader.as far as the brakes it a maintance thing.put a new wheel cly on that was leaking,worked good but the more i used it there wore.i know you can high low steer but i also like to skid steer at stop.if it came with it id like it to work.looks like the disk is cheap.now how hard is it to change.
alrman
06-17-2005 01:03:32
Make sure you use stainless steel spit pins on the internal clevis pins or you'll be doing it again in no time - cheers
stressfree
06-17-2005 01:40:30
 Re: anybody change brakes on a case 450 in reply to alrman, 06-17-2005 01:03:32
how are they to work on?
alrman
06-17-2005 05:04:17
 Re: anybody change brakes on a case 450 in reply to stressfree, 06-17-2005 01:40:30
you need to be pretty thin / need two elbows on one arm / 10 inch long & very strong fingers / a steel rib cage / but apart from that you should have a barrel of laughs ( if you get my drift)
cheers
