Help .... Oil types and capacities on a Cat D7-17A
andy r
06-24-2005 23:34:25
I do not have an owners manual yet for my D7. What are the oil compartments that need changing, what are the capacities and what type of oil is used? Off the top of my head the different oil compartments are 1) the main engine 2) the wet clutch 3)the transmission, 4) the final drives on each side, 5) the gearbox that drives the cable unit on back and 6) the pony motor. Am I right in saying this dozer has a booster on the steering clutches and the brakes are manual? Or, is it the other way around? Where does this booster oil come from? Are there anymore????? What type of oil goes in each? I do know the rollers and idlers need oil inside. Any other lubrication necessary beside grease zerks??? Thanks ... andy
hector gemme
06-25-2005 09:56:35
 Re: Help .... Oil types and capacities on a Cat D7 in reply to andy r, 06-24-2005 23:34:25
hi tHE MAINE ENGINE USE 15-40 5 1/2GAL,THE MAINE CLUCH SAME OIL 5 GAL.,TRANSMISSION 80-90 10¾GAL,FINAL DRIVE 80-90 5¾ GAL EACH SIDE AND THE STERING BOOSTER YOU FILL BY BIG PLUG AND THE BACK AND I HAVE SOME USE PARTS FOR D7.HECTOR
