Hd6G quit pulling
Tim B in WV
06-25-2005 14:54:38
Hey,Guys'
Got a problem with the left-side of my loader quit pulling.Pulled the seat/batt.box/top cover/steering brake band.the throwout arm for the clutch is pivoting at the middle of the arm. Shouldn't this pivot at the bottom of the arm?Is the only way to remove the clutch assembly thru the top? Have to remove axle/sprocket?Looks like the way to me and I'm not looking forward to it. Any help appreciated.Thank You!
hector gemme
06-25-2005 15:43:16
 Re: Hd6G quit pulling in reply to Tim B in WV, 06-25-2005 14:54:38
HI For pulling stering cluch you take off the fuel tank and the hydrolique pipe and the plate cover,take off the plug 1 inch behing top sprocket ,by this hole you pull the break band pine and after you take off each side bolt stering,you better live the band break inside for pulling the stering cluch, I have some use hd6 parts,if you have probleme send me é-mail. HECTOR
