case 310g wont move anymore
kenperry
06-28-2005 16:59:26
Hi
Was using my 310G crawler/loader tonight and it stopped moving! When I pull on the right handle i get power to the left track but nothing to the right side. No noises or any warning just stopped.
Does this have steering clutches or brakes? Any ideas on what i should check or adjust? Thanks Ken
SteveGr
07-01-2005 18:48:06
 Re: case 310g wont move anymore in reply to kenperry, 06-28-2005 16:59:26
The 310 has differential steer. Which means a brake slows one side down so you can make a steer. It sounds like that you broke the diffential. To check pull the rear cover off in back by the final drives under the seat. You should be able to see the diff. If anything is broke it will be very obvious. You can operate the machine to test, just have someone watch as you do this.
