Track tensions
Case450
07-05-2005 11:12:13
Approximately how tight should the tracks be? If there is a "too tight" what would happen to the machine or undercarriage? Also, one side of my machine seems to loosen up quicker than the other. Would that be a bad seal somewhere or what? Thanks.
Dale(MO)
07-06-2005 07:51:50
 Re: Track tensions in reply to Case450, 07-05-2005 11:12:13
There is a "too tight". It can cause undo wear on the pins and bushings, the idler and its bushings/bearings, final drive bearings and seals - pretty much the entire undercarriage.
The way I was always taught to set the tension is: 1. Park on a level surface. 2. Make sure you have a track pin at 12:00 on the top roller. 3. Lay a straight edge on the track from the idler to the top roller. 4. Measure the slack. It should be between 1 1/2 - 2 1/2 inches.
As for the leaking adjuster, it could be the seal. See if you can see any grease seeping around the seal area. Unfortunately, they never seem to scab over and heal themselves.
Hope this helps.
Good luck,
Dale(MO)
